3164 Vistas, 7 Respuestas
Mleader: text on different layers within text
Hello Autodesk Community,
I have been working to solve this problem for months now and figured its time to see if Autodesk community can help. I have researched many forums and seen that I am not the only that needs help with this simple patch from Autodesk. At my job, we use mleaders for structure callouts with rims, inverts, type ect. See picture below:
We have lisp routines so we can cycle through different plan sets such as grading, utility, geometry, demolition ect. The issue is I would like the first two lines (the structure type and rim elevation) to be on one layer while the inverts and all other directives are on another. Mleaders do not allow you to change the individual lines of text onto different layers. I have tried creating custom blocks to insert as my leader landing, using attributes ect and have gotten close to what I need but feel like this should be a simple fix from Autodesk. The only successful workaround is just to create another separate mtext and line it up below the existing leader. The issue here is if you change the annotation scale or need to move both the rim text and the invert text, the handles for moving the objects need to be in the same spot.
The whole exercise is needed so that the rim elevations will show up on the grading plan but not the inverts. But then when cycling through lisps and going to the utility plan both will show up.
I have attached a dwg file of the three scenarios:
1.) This is the most ideal, have an mleader with the text in pink on a different layer than the text in yellow.
2.) Having a seperate mtext below the leader and just eye balling the alignment in case changes are needed.
3.) Having a seperate mtext below the leader but the handles are perfectly aligned, so if moved, you have to select both entities and move from the mleaders handle.
Any help solving this would be awesome. Sorry for any rambling or misspelling!
Cade
Etiquetas (5)
