402 Vistas, 2 Respuestas
Only able to see 3 views at a time on the sheet
Hello.
I created a View file and placed xrefs. I then created viewports for each drawing. Then I go to the sheet and try to place the viewports. I can place only up to 3 viewports because as soon as I place the 4+ views onto the sheet, one of the existing one goes blank. However when I go to print, they are all there.
Any idea of what's happening? I tried creating a view file for each drawing and placing it onto the sheet but I am having the same problem. It seems like my 24x36 sheet only allows me to view 3 viewports at a time?
See attached image for reference.
Thank you.
john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
Can you tell me what your MAXACTVP is set to? I suggest setting it to 64. Please let me know if this helps.
John Vellek
en respuesta a: john.vellek
Thank you so much.
That was the problem. It was set to 4 but now I set it to 50.
I also changed the dwt so that the subsequent sheets have the same template.
