pendean
en respuesta a: Anonymous
You draw at 1:1.
To fit your building on paper, you will need to scale the viewport in the layout (not the actual drawing) so it will fit on a page.
If you do not wish to print to a scale (your current setup does not either), you can skip that part and issue your plans with dimensions only without a scale.
Either way, your real issue is you are not correctly choosing WHAT TO PLOT in the plot command pop-up window. That's all.
