Washingtonn
en respuesta a: Anonymous
@Anonymous wrote:
Please can you tell me what it is the total length of this rod ? That is how to straight the bend.
And what way are you using to calculate this. Is there any method to straight the bend section to find the total length/
Please note that the original drawing lacked some information and due to this, assumptions were made. You have not confirmed the assumptions as correct or provide corrected information. The video was created showing a method (based on assumptions) to draw the part. We didn't even have information as to whether that the part was round or flat.
As for the total length of the rod (part now verified as being "round"), you could and should Goggle 'Bend Allowance' and figure the length out yourself because:
1. We still do not have confirmation regarding the missing information/dimensions (diameters, metric or imperial units, and now material ) - so a "length" would once more be based on assumptions.
2. If this is a class assignment you need to learn how to do it for yourself - it may be on the next test.
3. If this is a work assignment you need to learn how to do it for yourself - you may have a similar problem in the future.
