parkr4st
en respuesta a: john.vellek
John
Question for you.  You set from the right end of the first line, 327, 32 units and then used that point for the left most end of the 4 R units arc.
That off set is in reality 32 + the diameter, width, or thickness of the item?
There is no proof in the picture of the item as to its shape.  That could be the side view of a 3 x 34567 wide flat plate with a couple of dados across it for all we know.
I contend that insufficient information is available to correctly draw the item and without the A-A profile it can't be done except by the guess method.
Could you enlighten me?
Dave
