02-28-2017
08:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-28-2017
08:20 AM
Hi @Anonymous,
Did you try the steps I gave you on your own? It is the best way to learn - by doing - ![]()
So again, I want to start by scaling the strip portion fits the fillet area. I do this with the SCALE command.
I then move the Pins to the flat part of the "cube".
Next I rotate the rest of the strip to be oriented vertically.
Lastly, I use project the geometry onto the "cube".
I am still not sure about the way you want the exact geometry to be projected as your fan is not square on the bottom as you show in your PowerPoint. But, the steps should be the same. Please give this a try and let me know if you get stuck at some point.
John Vellek
