- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
Kindly please try and explain the process followed, i.e. the dimensions made before applying fillet radius.
I think you will need to do the Filleting on some starting-assumption linework, and then adjust certain dimensions from the results. That may be the only way to get the endpoints of the curves to be in the correct positions.
One thing the diagram does not seem to show is the pipe diameter. If the inside radius at the longer/upper curve is 4.0 as at the shorter/lower curve, then the pipe diameter would be 8.0 [rather different from @john.vellek's assumption of 5]. Is that a realistic assumption?
[I also find it very peculiar that they would dimension the angled portion at 240 degrees swinging all the way around like that, rather than at the more-obvious 60-degree acute angle. This doesn't seem like a very good textbook, if that's where this comes from.]
