02-27-2017
09:37 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-27-2017
09:37 AM
Hi Priya,
I suggest that you create a Page Setup that can be applied to your layout. In the page setup, you can select a print driver such AutoCAD PDF. You can then also select what you want to print (Extent, Layout, Display, Window), The scale (usually 1:1), paper size and orientation and also select the plot style.
Once you have configured all of these options your resulting PDF should be correct and be able to be sent to your printing service.
If you would like to attach your final drawing with a border in the layout, I can suggest some settings for you.
John Vellek
