02-27-2017
07:11 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-27-2017
07:11 AM
@Anonymous wrote:
.... When a normal circle is created, from the point you start till the radius you want, you see the circle.
I want to create an isocircle so that I see it from the start. All it does is shows me a dotted line till the first click then it will show me the ellipse. ....
@GrantsPirate's suggestion in Post 2 -- ELLIPSE command when in Isometric mode, Isocircle option [which doesn't appear when you're not in Isometric mode] -- is exactly what you want, unless your problem is actually something different from what you describe above. You replied about his sign-off line, but haven't indicated yet whether it works for you [or whether you've even tried it, nor have you marked it as the Solution, but I believe it truly is].
Kent Cooper, AIA
