en respuesta a: swieciakpawel
Yes, I see.
I understand that is a sort of specific/unusual problem, which in many other cases shouldn't be adjust at all. But in my case it would be reasonable to hide this lines, because they just clutter the drawing.
"But personally, I'd just make those blocks correctly if this was so important to have no lines" – the is that the elements modeled correctly. It will be an edge there, because the arc of this element consist two different radiuses, and the connection between those two radiuses is not a tangential.
But thank you anyway.
