swieciakpawel
en respuesta a: Anonymous
Well unfortunately You cannot just hide/remove a single edge of a 3d solid without editing it.
If You would change the material transparency to 100% You would be left with empty screen.
Instead, I would try some crude methods to solve Your problem.. It's not really nice way to sort this out, but that's just first thing that I would use if I had to make drawing as soon as possible.
You can use VIEWBASE command to create Top View of Your elements
Then copy the model elements into the Layout with the Viewbase.
Freeze the "TunElem_Roof" within this viewport.
Result:
But personally, I'd just make those blocks correctly if this was so important to have no lines.
Kind Regards,
Pawel
