neaton
en respuesta a: Anonymous
Just watched the video and had a good laugh. It took twice as long to copy and paste all the lines. I hope you are using direct input and osnaps to reduce the number of steps. CLT-E switches the isoplane from Left, Top or Right. As you can see in the Screencast the ellipse iso circle appears as you enter it, there is no dotted line unless you forget to select Isometric in the ellipse command.
I am not sure why you need to select Hatch twice to get the tab to appear. Mine appears when the Hatch command is started.
If you are doing this for fun you might want to try creating your drawings using 3D. It is a lot of fun and with all the Youtube videos out there it is pretty easy to learn even for folks like me who started drafting before ACAD was invented Emoticono sacando la lengua
Nancy
