en respuesta a: Anonymous
Why would it matter if the Intel is disabled. Every other application for windows knows to pull the proper video card. Nothing else is using the Intel. So by disabling it you are doing no harm to anything else.
As Pendean said, There is no other solution. The only way to force autocad to use the higher end card is to flat out disable the Intel integrated card in the BIOS not in Device manager. Disabling it in Device manager doesn't do squat.
