RobDraw
en respuesta a: RocksterB
If you are trying to assign a page set-up from the plot dialog box, you would need to also apply it to the layout by hitting the button or to have changes automatically applied to the layout. Also, if you are not familiar with it, look into the page Setup Manager.
I'm guessing you are getting different results when None is the current page set-up and not the desired named plot style. As stated earlier, you can apply page set-ups from within publisher. I do this when I think there is any chance that the desired one may not be current in the files I am publishing, which, in a multi-user environment, is almost every time. That is why having a file handy that has commonly used set-ups for importing is such a good idea.
Rob
