RobDraw
en respuesta a: Anonymous
@Anonymous wrote:
I don't believe PLOT uses what is in the page setup if there is something else saved to the layout. It only defaults to the page setup if you have nothing saved to the layout.
Not quite true. The [named] page set-up should be assigned to the layout. If a change is made to the page set-up settings during plotting or otherwise and applied to the layout, the named page set-up is no longer current and needs to be re-set as such. This can be done with the page set-up manager or it can be done in publisher as a temporary override, When doing this the page set-up that was current when the file was last saved will remain current.
The rest of your post is solid advice.
Rob
