en respuesta a: RocksterB
I don't believe PLOT uses what is in the page setup if there is something else saved to the layout. It only defaults to the page setup if you have nothing saved to the layout. So you could have a paper size saved in the PLOT dialog and that paper size is missing in the page setup.
From the page setup dialog, you can import another page setup from a drawing that you know is working, even if it has the exact same name. You'll get a request to override the existing one, choose yes. Then save the page setup, and it should publish correctly.
I have a drawing with previously edited and saved page setups, so I can always import from a source I know works. I try to remember to do that on the first drawing in a new job so it's available in the current job folder..
If you're in a hurry and have a ton of errors in your page setups, while in the PUBLISH dialog, go to a sheet with a page setup that works, move it to the top of the list. Select all files in the list, click it in the pull down, and that page setup will be applied to all.
If print order is important, then you'll need to edit the page setup for the first drawing at the top of the list, but you won't have to do them all.
