Hi RocksterB,
I would check the following things first.
1. Do you have enough papers with the same size in your printer to plot as publish does a batch plot ?
2. Try installing the latest drivers from the vendor website.
3. Are you using any addins or custom applications on top of AutoCAD, if so try unloading them and test the publish command whether it works or not.
Let us know the results for the above.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
