TonyRB
en respuesta a: john.vellek
Hello Autodesk Help,
Allow me to clarify. Context (right carrot) pull down menus right of center of screen now open to the left as opposed to how they've opened for years which is to the right (unless at the edge of the physical screen).
This change happened without an event of any kind, just a normal, voluntary system restart.
It seems as though Acad is sensing a smaller screen or something similar because right carrot pull down menus at the far left of the screen still open to the right.
Another issue I'm dealing with is Acad 2017 will not remember my screen setup. Every time a launch a session, the Ribbon, layer, xref and properties toolbars vanish.
I've read every article I can find to resolve this problem to no avail. I'm not going to rebuild my entire setup to fix this problem so I suppose that means I just live with it.
Not horrible but it doesn't speak very well of this version of your product IMHO.
Thank you.
Tony R Burke
Klai Juba Wald Architects
TBurke@klaijuba.com
p.702.221.2254 | f. 702.221.7655
www.klaijuba.com
4444 West Russell Road, Suite J, Las Vegas, NV 89118
CAUTION: electronic mail sent through the internet is not secure and could be intercepted by a third party. NOTICE: The information in this message is intended only for the personal and confidential use of the designated recipient(s) named above and contains information that is privileged and confidential. The recipient may not use or disclose this message (or any portion), except for the sole purpose for which it has been sent. If you have reason to believe that you are not the intended recipient, please notify the sender, delete it and do not read, act upon, print, disclose, copy, retain or redistribute it. This communication by itself is not intended to form a contract by electronic means and nothing in this message is intended to constitute an electronic signature.
