787 Vistas, 8 Respuestas
SAVEAS file format
AutoCAD 2017 we have, and we save all .dwg files on 2010 file format.
but it will auto save on upper version. We cant able to open that file save in upper version.
we always save in 2010 format. Why it saves in upper version file format??
Alfred.NESWADBA
en respuesta a: Anonymous
It's not the best solution to save all drawing to old DWG formats!
Converts objects to old DWG formats AutoCAD has to convert that objects (so these dwg files can be opened to old AutoCAD's)
If you open such converted dwg files with AutoCAD 2017 the old geometries are again be converted to the new objects types.
That means save as well as open is slower (because of converting geometry types)
Always it's like puzzle, sometime opening such converted to old dwg formats opening such a file with newer AutoCAD might fail, hard to repair that.
My suggestion:
Save the drawing with the newest dwg format
If anyone needs an old dwg format, then use command _SAVEAS ... but do this only as a copy of the drawing,
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
I have 20 users that use AutoCAD 2017 and other 10 users have AutoCAD 2010.
who those use 2017 they save files in 2010 format because other user has also work in that files. but sometime a file save in 2010 it cannot open in AutoCAD 2010, It says that the file has a upper version.
Alfred.NESWADBA
Upload such a drawing, so we can look, what geometry type it contains.
- alfred -
Alfred NESWADBA
pendean
That happens due to your chosen method of saving down.
Your 2017 users need to use AECTOACAD command to properly knock files down to 2010-format to avoid all issues.
If you only want to use the default-save-settings or SAVEAS command, your noted "sometimes" issue will happen and a 2017 user need to go back and fix that one file "sometimes" when it happens.
john.vellek
Hi @Anonymous,
In addition to the great suggestions already in this thread, I suggest that you keep everything in 2013 file format. Your 2010 users can use DWG Trueview/Design Review to convert the files  to 2010 and even do entire folders at once. Realize though that loss of newer features doesn't help your 2017 users very much.
Of course your 2010 users are also using 8 year old software so it might be time to consider getting everyone on the same version. (operating system compatibility, driver compatibility, file versioning, etc) It might save enough time in the workflow to justify the upgrade costs. Just my two cents - I am not here selling anything.
John Vellek
Autosave is meant ONLY to mitigate a catastrophic failure.  It is NOT meant as a means of saving working files.  Your autosave directory should never be your working directory, it should be a different directory, better yet a different drive all together.
In your OPTIONS dialog box under the "Open and Save" tab make sure all users have the "Save as" ACAD 2010.
john.vellek
Hi @Anonymous,
I think @Anonymous perhaps got your meaning:
Rculp: "In your OPTIONS dialog box under the "Open and Save" tab make sure all users have the "Save as" ACAD 2010."
Here is what that looks like in OPTIONS
John Vellek
RobDraw
en respuesta a: john.vellek
@john.vellek wrote:
Hi @Anonymous,
Even though that option is there. It does not convert newer objects and features. You still get the message that the files contains objects created with a newer version. IMHO, that option should be removed or fixed. That is why converting the files with your chosen method is the proper way to do it.
Rob
