en respuesta a: Anonymous
OK good, tops are flat, that eliminates SLICE, and means a post "block" is in order, but poses additional questions.
Is the post spacing critical, and is is evenly spaced in "plan" or along the angled vector?? 2 meters in "plan" is different than 2 meters along the sloped line
See, functions like an ARRAY via path or MEASURE or rotating the UCS and using a rectangular array, will provide spacing normal to the sloped vector and NOT to a "plan" spacing.  If your spacing is relative to the sloped line, any of those methods would work, I'm partial to either the ARRAY Path method or MEASURE.
However, if the spacing is normal to a "plan" view, it gets trickier and requires either some troublesome trigonometry, or creative construction lines.
