02-14-2017
02:33 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-14-2017
02:33 PM
True there seems to be a lot of info missing. However, if the surface is truly complex, building it simply to cut the tops of the posts seems a bit of overkill, quite a bit of overkill unless the grade surface already exists. But then again if the surface does exist already a block with the insertion point at grade with the right post height above will still probably be less work than building the surface.
