en respuesta a: Anonymous
Do you want the tops of all the posts to be "flat" or sloped to match the angle??
If you want them sloped, use the SLICE command with 3 points.
If you want them flat, I would (personally) use a block for the posts with the insertion point at the middle of the top of the post, scribe a line at the elevations and place the posts along that line (MEASURE or DIVIDE).
