john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
Weird huh?  Is your PGP file in a unique location (non-standard)? If you type CC does it still work (you might have to turn off AutoComplete to test).  I created your alias on my side and it works fine.
Perhaps another thing to try is to edit the PGP file using Notepad.  You might also check to see if you have any other entries for CC or if you have any other routines that use it.  Perhaps try a unique set of characters such as ZX. (Just to test)
The Aliases I added show up at the very bottom of the PGP file under the section labeled User Defined Command Aliases.
John Vellek
