en respuesta a: john.vellek
Hi @john.vellek,
thanks for the suggestion but your solution is partially suitable to my problem.
If I enable the option to synchronize the table properties to the Excel file, it works and doesn't give me problem when I close and reopen the drawing, as you said. BUT I can't set all the parameters that I want from Excel, for example it's not easy to change the font and the cell size because Excel and AutoCAD uses different scale or it's impossible to change the spacing inside a single cell from the text and the borders, as I can do in AutoCAD with the property Horizontal and Vertical cell margin. (All of these maybe because my limited AutoCAD knowledge).
What I've done to solve the problem is use a little trick and avoid the Table Interruption at all. So I've created different excel sheets for the same table if I know will paste it in different parts (hope I explained well).
So, if you agree, I think I will mark this message as solution of my problem for the future users.
