en respuesta a: john.vellek
Hi @john.vellek, I'm attaching two files to this post.
One is a simple dwg containing two similar tables with "table interruption" enabled on both: first one was created with data added manually by me (titled "no link") , second one has the data taken from the xlsx file attached ("Cartel1").
I formatted both the tables with the same parameters (text heights: 2, cell width: 15, Vertical and horizontal cell margin: 0.6).
As you will see when you'll open the file, the first table parameters are OK but the second one have the good parameter JUST on the left part of the table, the first rows; the following part had changed them with no reason!
Thanks for your help
Andrea
