1311 Vistas, 8 Respuestas
Problem with proprerties of an excel data link Table
Hello to all,
this is my first request post, I hope I'm explaining it clearly :
(I'm using AutoCAD 2013).
I've added some excel data link tables to the Layout of my dwg (Layer 0).
I've needed to change their proprieties to fit them properly in the drawing with the same aspect: changed the text style, text height, cell width and length.
Then I've enabled the table interruption of a specific table to extend it to the right (no more space under it) and moved the extension to a wanted position (I enabled the "manual position" voice).
The problem is that, if i save and close this dwg and then reopen it, the properties of the extensions of the table with enabled interruption, are changed! Some of them have a very small text height, some other have a bigger one!
What can I do to fix it?
