david4528H
2347 Vistas, 5 Respuestas
Material preview generator has stopped working
I am having an ongoing problem that is more of anoyance than a hinderence, I have googled it but found nothing.  It happens on occasion while I am working but more often than not while changing between drawings. ( I tend to have 2-6 drawings open at a time) I do both 2D and 3D drawings.  I get the pop up  "Autodesk Material Preview Generator has stopped working- Search for a solution or close the program"  searching returns nothing, so I close the program.  10 -15 min later  same thing. (how is it crashing again if i just closed the program?) Some times I can go days in between crashes. It doesnt affect the ability to view materials I have applied to 3D objects in realistic view.  Autocad 2017, Win 7 Pro, 24gb ram, 8 cores, 8 gb video card, AC is on a 240gb SSD drive ,1 TB HD on computer, drawings are stored on server.   So I dont believe its a hardware issue.    Any thoughts?
pendean
en respuesta a: david4528H
Is this a sudden new problem?
Or is it limited to certain files you have open?
david4528H
en respuesta a: pendean
Its not realatively new has happpened for maybe 8-10 months  seems more frequent lately.  Not sure if it is exclusive to 2017 or started before I upgraded.
Its not a certain drawing(s) that seems to be the culprit. Since a whole different group of drawings could be open every time it happens.  It could be going from one open 2D drawing to another 2D or from a 3D to a 2D  no real rhyme or reason to when it happens.
john.vellek
Hi @david4528H,
This is a new one on me and I don't see any information in the AKN regarding this error message.
Can you give me more detail on what you have open / running when this occurs? For instance is the Material Browser open at the time? Are you editing a material in the Editor? Is there a specific Visualization Style being applied?
Have you applied the Service Pack and Updates to your AutoCAD?
John Vellek
david4528H
en respuesta a: john.vellek
It just did it again.  Below are the details from the error pop up. Autocad is fully up to date.   I am in 2D wire visualization.   Right now I do have  the material browser open.  It has done it when not open.  I have 6 drawings open presently.  1 of which is a 3D,  Other programs i have running are Adobe Reader, outlook, excel, server file folders, IE and firefox, VLC media player. MS photo viewer. As I mentioned in my first post given the MB I have and memory I highly doubt its a memory issue.   As far as i can remember its not occurred while editing a material or in another visual style than 2D wire.
Problem signature:
Problem Event Name: APPCRASH
Application Name: AdPreviewGenerator.exe
Application Version: 2015.11.1.0
Application Timestamp: 56533e6b
Fault Module Name: AdMaterialUI.dll
Fault Module Version: 2015.11.1.0
Fault Module Timestamp: 56533e5f
Exception Code: c0000005
Exception Offset: 000000000012f5d3
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 131c
Additional Information 2: 131ccb9dbcb1ef4dcb7956b33c73e289
Additional Information 3: ccce
Additional Information 4: cccedf40988cfcd16ebe296b93d02256
john.vellek
Hi @david4528H,
Can you tell me which graphics card you are using and the driver you have installed?  Any issues I see that seem possibly related have to do with hardware acceleration. I would like to see if your Graphics card is on the certified list (and therefore which driver) or to see if there is a more current driver that might behave better.
John Vellek
