- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Copy Sheet Set Custom Properties to another Sheet Set
Hi. I would like to add a revision block driven by Sheet Set fields to several sets of drawings. There are a total of 30 Attribute Definitions in the block. I want the AttDefs to be driven by Custom Properties in my Sheet Set Properties. I think I can figure this out - essentially creating a field that links to each custom property. However the tricky part is that I want to copy this block to 15+ other projects that already have Sheet Sets.
So... I am looking for a way to copy or export/import the custom SS properties to the other project. Then I can copy the revision block to each sheet and hopefully the links will update in the other projects. I see there is a command called PROPULATE but as far as I can tell this is for transferring drawing properties (DWGPROPS), not Sheet Set Properties. Any guidance on this would be greatly appreciated.
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
