02-24-2017
11:56 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-24-2017
11:56 AM
I would convert the strip pattern to an image format then create a material from the image. For the sample I posted I rotated a planar map so that it was parallel to the front of the box.
The stp file you posted did not successfully import to AutoCAD. Can you post a .dwg file of the object? I can convert the dxf file to a jpg and give you the results.
How will the end result be used? Is a pictorial image of the result all that is needed or something else?
~Lee
lee.minardi
