gotphish001
en respuesta a: Anonymous
Draw the horizontal line first then the vertical line. Next measure back from the left 32 and draw a line from that point on the 240 angle to get the diagonal line. Use offset from your lines to get the thicken of the pipe, by offsetting lines half the width of the pipe each direction from the center line. Delete center line now as you don't need it. Now put in all the fillets. To figure out the inside fillet when they give you the outside radius, just subtract the width of pipe from the radius and use that number as the inside fillet radius. It's addition when you have the inside fillet radius and you need the outside one.
Nick DiPietro
Cad Manager/Monkey
