02-21-2017
10:40 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-21-2017
10:40 PM
>> in the dialog box of the Bpoly to uncheck the "retain boundaries" box, but it is disabled and you can not uncheck it. <<
it's is always disabled because it's controls whether the objects created are retained after the dialog box is closed.so it's not sense to make it active.
>> any ideas of how to erase the unneeded polylines? <<
there is a lot of ways to do that,herewith some of them:
- after you make your needed polyline by bpoly.use MOVE command and when asked for select object type L from (last) to move the bpoly object for known distance.then erase all unwanted objects then get back your last bpoly object.
- copy with base point the Last object with COPYBASE command.
- use special layer and start turning off and on.
Imad Habash
