- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi guys,
Using AutoCad 2013.
I have a problem, when trying to make to rectangles (or circles, etc.) into one polygon I use the Bpoly command.
I draw a line between the two rectangles and then pick the internal point as prompted.
The command itself does the work, but with a side effect.
It makes a new 2D polyline, which is fine, but does not erase the polylines I've drew before, I need to erase them manually, and it is one on top of the other, so you can imagine it is not the most fun...
There is an option though, in the dialog box of the Bpoly to uncheck the "retain boundaries" box, but it is disabled and you can not uncheck it.
Seems like this will fix the problem, any ideas? Or any ideas of how to erase the unneeded polylines?
Thank you
¡Resuelto! Ir a solución.
