02-22-2017
10:58 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-22-2017
10:58 PM
Beside feedback that @john.vellek already provided for You, I'd also like to add something:
1. Managing the Security Tab options in Your Internet Properties, could solve Your issue with Read-Only files, as this is common, for Windows, to block by default files originating from outside of Your hard drive.
2. You can try disabling the InfoCenter, for it was always common (at least for every version I've used) reason for AutoCAD hiccups.
I usually do this by changing the registry value, the Search for name "InfoCenterOn" should always return this one entry, and then You just change the default value from "1" to "0" like on the screenshot.
Kind Regards,
Pawel
