en respuesta a: imadHabash
Thanks imadhabash, but I had already tried that route. I even found some on youtube that show that it is possible. The problem is that AutoCAD keeps updating its software each and every year. So every thing that you are simply used to, just becomes more complex. The software developers need to stop making things simpler for themselves, and start thinking about the not-so-brainiacs.
Here is an example: Hatch - I used to be able to click the Hatch command and the selection of hatches appears. Now you click Hatch and a complete Tab would open, then you would have to click Hatch again to see the selections. Before, you used to be able to click Hatch and it would automatically give you that tab at the same time the selections are visible. They just made double the work and double the time.
https://www.youtube.com/watch?v=BNjqkKlCGBc
Type this address in and you will see this is what I want to do. You actually see your progress as the isometric circle you are drawing. AutoCAD program updaters' are making things more difficult.
