1288 Vistas, 2 Respuestas
Internal error: !dbutil.cpp@959 eHandleInUse
When I open my dwg file, it sends me a message with INTERNAL ERROR: !dbutil.cpp@959 eHandleInUse and the the program closes.
What's the solution for this problem ?
Thanks.
john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
This error typically means that you have some corruption in your file or in a block. I suggest that if you can start AutoCAD that you run RECOVERALL on your file to see if that corrects the problem. You are welcome to attach it to a post also so I can take a look more closely.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post solves your issue or answers your question.
John Vellek
