431 Vistas, 2 Respuestas
Line Style Display Changed
We are using AutoCAD 2015 and saving as version 2013.  I have a set of sanitary drawings (one is read only and hasn't been updated in a year).  All of a sudden when either drawings are opened, the sanitary line styles are very weird and notes are very choppy.  The line text "san" looks like a type of Greek letters now.  I have attached a picture of how the lines looked in the past & present.  There hasn't been any updates to the program nor the line styles which reside on our "C" drive.  I am not the only person that this issue is happening too.  The drawings are accessed thru our network drive.  I had thought something had changed to promote fast viewing (I didn't change anything myself, nor did any other user), but have not been able to find any evidence of any such a thing affecting line styles.  The drawing is extremely slow opening and regenerating now.  I have done a repair (nothing) and purge with no changes.
jayhar
en respuesta a: Anonymous
Can you please attach DWG file, let me check. Or check layer Line type and purge.Text.jpg
Check Text Style or Create New Style.
Thank you
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Alfred.NESWADBA
That means the linetype uses a textstyle which now points to a different font (or to a font that does not exist any more and so a replacement font is used).
So you need first to find out which textstyle the linetype is using and then look in your textstyles which font is set to the used textstyle.
Uploading your drawing would help us to help you ...
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
