MBF-CAD
en respuesta a: Anonymous
Replace this line of code   -->    (alert (strcat "Maximum Number is: " (rtos nmax)))
with the following 3 lines of code
(setq textpoint (getpoint "PICK LOCATION for ANSWER"))
(setq answer (strcat "Maximum Number is: " (rtos nmax)))
(command "text" textpoint "" "" answer)
Do the same as above for this line   -->   (alert (strcat "Minimum Number is: " (rtos nmin)))
(setq answer (strcat "Minimum Number is: " (rtos nmin)))
and finally  replace this line  -->  (alert (strcat "Average of " (rtos tents) " Numbers is: " (rtos ave)))
with the following lines
(setq answer (strcat "Average of " (rtos tents) " Numbers is: " (rtos ave)))
Make sure you have a copy of the original before making changes.
And please thank Lee McDonnell for the original code.
Hope this helps
