- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @mpa-la,
Thank you for posting. I've tested this here in a new drawing in AutoCAD 2016, and confirmed the behavior you described. If the justification is text justification is manually changed, it will no longer switch justification automically when the multileader is adjusted from one side to the other. Instead it maintains the justification that was manually set. There does not appear to be a method for reversing this once it's done.
This seems like expected behavior for a manual override, although it would be nice to have the option to restore the automatic justification behavior when you encounter multileaders that are overridden in this manner. I've just logged this with the development team on your behalf, so that it can be considered for a future release.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
