- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
My settings are as you indicated, except that I don't want them to always left justify, I want them to justify automatically depending on which side of the leader they're on. I've attached a dwg with my mleader. The top one is unadulterated, the bottom one has been set to right justify in the text editor, as you can see if you select it. It has an extra grip on the top right. The left and right attachment settings remain the same in the change properties box becuase the change was made in the editor, not on the overall entity. The change property box does indicate that it is right justified, but will not let you change it, it just flips back to right.
As a point of interest, if you leave your change properties box open, then move the text on the top leader by grips you can see it change from left to right in the properties box, but if you do the same thing with the bottom one, it doesn't change.
Again, this is not a problem I'm creating, I know how to setup and use mleaders up correctly, it's junk drafting I'm trying to clean up from other people's drawings. I have figured out how they're causing the problem, but I don't think there's a fix.
