mpa-la
en respuesta a: pendean
I'm talking about mleaders that someone improperly edits to add justification within the text editor.  Try it yourself.  Make an mleader and move the text back and forth with the grip and watch the justification change automatically.  Then, edit the text, and in the text editor click one of the justification buttons.  Then try moving the text to the left and right and see that the justification no longer changes when you move it.  It always stays where you put it in the editor.  It's similar to editor overrides in mtext.  Changes in the editor override the overall properties of the object, the difference being that you can clear overrides from mtext, but I can't find a way to clear this override from mleaders once they're there.
