526 Vistas, 4 Respuestas
Strange plotting behavior
A very unusual problem has popped up when plotting to Bluebeam PDF Revu from AutoCAD 2014.  I do a <cntrl> P to plot, pick the Bluebeam either the Bluebeam PDF or a preset I've created in the Page Setup Manager, click the OK button, and nothing happens.  AutoCAD tells me it plotted with the notification balloon, but the file doesn't open.  I do a second plot.  Sometimes this one goes through and the file opens in Bluebeam, and sometimes it doesn't.  I've had to go through this procedure multiple times (the most was four) before I can get a plot.  This doesn't happen when I use Publish, only when I have single details or sheets to plot.
The really interesting thing is that now I have four Bluebeam PC3 files.  Please see attached PDF file.  These are named Bluebeam PDF.pc3, Bluebeam PDFa.pc3, Bluebeam PDFaa.pc3, Bluebeam PDFaaa.pc3.  I have also contacted Bluebeam with this issue.  Any and all help greatly appreciated.
Etiquetas (1)
pendean
en respuesta a: Anonymous
Bluebeam support is here for those that are wondering, while you wait for users to guess from your topic title that you need Bluebeam users to help you out http://www.bluebeam.com/us/support/
en respuesta a: pendean
Thank you.. I took the hint. :cara_con_una_leve_sonrisa:  I've already contacted Bluebeam and am waiting to hear from them.
I am currently running throught the same issue. Did you ever find the solution?
It also seems as tho my Adobe PDF plot selection was replaced by Bluebeam so
I can't even plot as a different PDF program.
pendean
