- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
... .i wish that lisp to ask (select room dimension, no of column, no of row, column spacing, row spacing, pick block, block visibility, then ok)
have you any lisp like that.....
I don't have anything exactly like that, but I wonder about some things....
if you're going to give it the number and spacing of both rows and columns, it seems to me that ARRAY or MINSERT would do almost all of that for you, without any custom routine.
If it asks for all four of those things, the room dimension wouldn't have any influence. So maybe you want something more like this routine. It's about sprinkler heads, and it has a maximum spacing between heads, from which and the room dimension it calculates the number required in one direction and the actual spacing. And it has a maximum coverage area per sprinkler head, from which and the actual spacing in the first direction and the room dimension, it calculates the number and spacing in the other direction. Would something like that work for light fixtures, if their lumen output and the required light level can be used to define a maximum spacing and maximum coverage area? That routine could be modified pretty easily for that kind of application.
