Kent1Cooper
en respuesta a: Anonymous
@Anonymous wrote:
I current have a LISP that will create an arc from one to another from the center of the fixture and will trim the arc within the circle of each fixture. Currently it only allows you to do one to the other but I often have multiple rows and it would be nice to select the first one thru the last one and it will do the same with each fixture in that row.
I've contributed some things to threads on such topics, some of which you've been a participant in, but there are different approaches from other people on them, too.  Can you post the routine you're using?  It may be comparatively simple to adjust it.
Are you willing to select them by picking one at a time in order [more trouble for the User, but much simpler code for the Arc creation], or would you want to select a whole row, for example by Window [simpler for the User, but more complicated code to determine the order]?
Kent Cooper, AIA
