steve216586
en respuesta a: Anonymous
See attached for untrimmed and trimmed version dimensioned.
To find the 1.25 radius you must create construction lines:
1.  mirror the tangent line at the top line, using the center line labelled 4"
2.  draw tangent line from lower circle at 135 degrees
3.  draw circle using TTR between the two using 1.25 as radius
There is enough information given to complete this part. Don't listen to the other posters. There is nothing wrong with the excercise.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
