BeKirra
en respuesta a: asherjoh
1) Copy my code to NotePad then save it as ThroatSize.lsp
2) Move this file to
    C:\USERS\YourName\APPDATA\ROAMING\AUTODESK\AUTOCAD MECHANICAL 2014\R19.1\ENU\ACADM
    (Note: Your AutoCAD version may be different to mine but the path should be very similar.)
3) In AutoCAD Click "Load Application..." under "Tools" tab (or type _appload in command line), after Selecting ThroatSize.lsp then click "Load" button then "Close".
4) Now you are ready to use the code - type DuctThroat (not case sensitive) in the command line then click your "Enter" key.
5) Follow the instructions showed in the command line - you should be fine.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
