en respuesta a: Anonymous
Again ,it depends of the type of object, and the answer will not be the same if you consider a line or a polyline for example.
For a line you can directly change the start and endpoint coordinates in the properties dialog, fo a polyline, you can change the current vertex and edit its coordinates in the properties.
