1798 Vistas, 12 Respuestas
Problem with elminating nodes
I am relatively new at AutoCAD. I converted a .png image to a line drawing .dxf file in CorelDraw. I can open the .dxf in AutoCAD, however there are an overwhelming number of nodes in the line drawing. How do I eliminate the nodes but maintain the intergrity of the line drawing? From AutoCAD, I need to transfer the file to Sheet Cam, which then allows me to convert to a .tap file then to gcode. Then in Mach3 I open the gcode and operate my cnc plasma cutter.
Eliminating the nodes should create a smoother cut path. Thoughts?
