Kent1Cooper
en respuesta a: bwhisenhunt
@bwhisenhunt wrote:
That helped, I found I needed to change the Delta-Y as well. So this is what worked:
0, 0,0, 0,4
90, 0,0, 4,-5.3333, 4,-8
You mean the pen-up portion [the Delta-Y is the part I changed].  And yes, of course, with the different stagger, there are a different number of tiles to cross over before arriving at another joint in the same line -- I might have realized that if I'd thought it through more thoroughly, or [what a concept!] actually tested it.
Kent Cooper, AIA
