- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Model Space or Paper Space
Paper Space or Model Space.
Where do text and dimensions belong?
Everyone has their own opinions and so have I.
I believe graphics including xrefs belong in model space, and text, dimensions, section marks, drawing borders etc. belongs on paper space. No need for scaling and linetype scaling this way.
Any thoughts?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I definitely understand why you put text and dimensions in paper space, I used to do that myself. However, I have created blocks with attributes for tags, and blocks of each of my dimension types, each set to the correct plotting scale, and placed those blocks in my tools pallet (which stays open) and its as easy as drag and drop. I work in a field that has constant drawing changes and to make those changes in model space then go back to paper space and adjust dimension strings and text placement becomes a hassle. Since I use the stretch command often, my dimension strings and text placement can move with it. Now the only thing I need to do in Paperspace is check the viewport boundaries to confirm that my drawing changes are still within the window.
One that note, I have also customized my most used hatches to their proper plot scales and placed them in my pallet also, in addition to dimensions and and hatches, all of my other blocks (regular and dynamic) are stored here on corresponding tabs. For example, since we always plot floor plans and elevations to 3/4" scale, I have a "PLAN" and "ELEV" tab which includes, MTEXT, QLEADER, DIMCONTINUE, DIMLINEAR, and so on. I have tabs for sections and detail labeled by scale: 1.5", 3", 6", & 1:1. Blocks are on tabs labeled by category (ie. electrical, accessories, plumbing, etc).
This has been a game changer, drag and drop is the way to go!
Hope you find something useful here.
Best,
Tiffiny
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
for those who dimension and text in paper space, please puut these things on segregated layer so others can turn off when they use your model
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
"Everyone has their own opinions and so have I.
Any thoughts? "
Your mind is made up. Go with it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
The age old dilemma...
Any thoughts?
I believe the real issue is about setting up drawing scale & your company drawing standard while I agree that "Everyone has their own opinions and so have I". In other words, you may have to be in a position of CAD manager & instruct your colleagues/sub-contractors to follow your standard.
In my career I have seen a lot of users switching MS & PS all time for modifying/checking their drawings when they think the texts, dimensions and so on belong to PS.
IMO if you can setup your drawing scale properly, you will love to stay in MS. And create your own drawing scale tool (i.e. AutoLisp routine) will make your life a lot easier.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I'm not following this.... If something is in Paperspace, then it's never going to show up when someone else uses the dwg as an XRef. I'm more troubled by Model Space notes/dims/annotation, and the need to have those on layers that can be readily turned off.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
without any paper space and layout tabs to be used for the sole purpose of
referencing.
Also another reason why text etc. should be in paper space. We all know how
some individuals like to disregard the use of the correct layers...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yeah, editing a post is only possible for a limited time, and never after there are anyadditional posts to a thread.
but we're on the same page re: dims & notes that end up in reference files, ![]()
