481 Vistas, 6 Respuestas
Can I get a DX to export to a preformatted Sheet
I am wondering if there is a way to create a templet that the DX function can use to make a table in excel. Right now I need to count hundreds of block with several attributes and I need them in a nice little table for excel so I can make an order and/or have the prefab dept create the items needed. Any suggestions are welcomed.
imadHabash
en respuesta a: Anonymous
Try EATTEXT command line...it may help.
Imad Habash
en respuesta a: imadHabash
That does not export the information it is just the attributes editor. I am looking to be able to DX into a premade excel sheet. Is that possible?
pendean
start HELP and in the search box type
About Data Extraction
and
DATAEXTRACTION (Command)
en respuesta a: pendean
I have been using the DX command and it dumps the information into an excel spreadsheet. Which is really good. However, I would like the spreadsheet that AutoCAD creates to be setup a certain way. IE font style, header, footer, column names, row names, highlighted areas.
pendean
Read through HELP: there is a lot of pre-setup, by you, that needs to happen in order for it all to appear in Excel the way you want.
I will look into the help section. Thank you for your help.
